BD Diesel Rocker switch to Jacobs Exahust brake wiring information
Buying '05, coolant question
New clutch
So here is how it works for any of you who may want to swap out your push pull switch on a 2003 to 2007 Cummins-Jacobs-Mopar switch for some reason, or if you order the replacement and find it is a headlight rocker switch designed to go in your dash...and you don't want that
The BD #1030900 rocker mounts to your manual shifter stalk, in 99-04+ trucks.
The Cummins headlight switch wiring hooks as follows.
Cummins to BD Switch
Black wire to Black wire
Red wire to Green wire
Yellow wire to White wire
There you go, hope this helps someone down the road.
