My exhaust brake stuck shut and it was disconnected by the Cummin's shop in Eugene, Or to correct a problem I was having with High EGT, low bosst and low power plus heavy black smoke.
I took it into a shop in Yuma, AZ and they said the valve was bad. I was told that the valve had to be serviced periodically. I wasn't aware of this. I used the brake nearly every day unti it locked up. This is the 2nd time I have had the brake stick closed.
Has anyone else had this problem? What type of maintainence is required on the valve? Help!
Dewdo in the other Washington
