I installed the BD gov spring kit in my truck yesterday and am very happy with the results. The truck now has much more rpm range and also seems to be more torquey in the low and mid range. I also replaced the light spring with the medium spring in the afc kit while I had it off because of excess smoke. I moved the #4 plate back . 050" as well because of excessively high exhaust temps. The truck now only has a puff of brown smoke which quickly goes away and has light grey smoke on heavy acceleration. Highest exhaust temp is about 1350 degrees. Before the changes, I could rent the truck out for fumigating, you could not see anything behind you if you floored it. The exhaust temps were going to 1500+ in a heart beat as well. I have seen a slight decrease in power with the max unloaded boost pressure dropping from 40 psig to 36 psig but the truck is now much better set up for day to day driving. I will be pulling my fifth wheel this weekend and am looking forward to the extended rpm range especially between 3rd and 4th gears. What kind of boost and temperature levels are others getting with this set up?
Steve
98 2500 Quad Cab, 12V, 5spd, 4x4, HD Transfer Case, 370HP Diamond B Injectors, #4 TST, 16cm2 Housing, AFC Spring Kit, Governor "Modified", Walker Muffler, 285/75-16 BFG AT's, SS Tube Steps, Fifth Whl Hitch, Leather, CD, LSD Dana 80 Rear, 60 Front, Centerforce Dual Friction Clutch, Rancho RS9000 Shocks, Rancho Steering Stabilizer
[This message has been edited by dieselburner (edited 11-05-2000). ]
Steve
