BD Plug-N-Power
Installed CATZ fogs in Sport Package and....
American Toolbox/Tank Combo???
B.G. Smith
Tried the BD and was very pleased with the power increase. Only problem is when I am pulling my 31' 5th wheel at moderate throttle the T/C chatters when it locks up, it does this in or out of overdrive. It works fine when I am accelerating or above 70 mph. I removed the BD and I can not make the T/C slip. I called BD and was told that now I would need to buy/installe the Pressure Lock to solve the problem?
Oh dear, the old transmission shudder, chatter thing again.
My BD Plug in Power was causing my, what I thought was transmission shudder, problem. Installed a BD torque Convertor, presure lock, and valve body. The problem still persisted until I swapped the BD PnP for a new one. My TC was chattering right before I installed the new one.
If you plan to keep this truck, spend the money and modify your transmission. This is a good investment.
I will not go into who makes the best this that are the other. I based my decision availability, customer service (who was close enough to service my truck in case of prloblems), and price. I am very happy with her now. Even at 102,000 miles.
If your TC is already chattering and shuddering, go ahead and replace it.
2001 3500 QC 24V SLT Larimie, leather, BD Plug in Power, 275 injectors, BD Torque Convertor ,Valve Body, Pressure Lock, Torque-loc, Gauges,Black w/ Ranchhand bumpers Brownes HD Headache rack and a black wetherguard coffin. pullee 34Ft. gooseneck and a 32ft x 6ft stock trailer.
2000 Durnago SLT 5. 9litre V8
B. G. :
I have a 96' 12 valve that had "major"
pump mods and 370's installed last year.
After these mods were done I also had
the "shudder" you describe. Scheid Diesel
installed the "BD Pressure Loc" and it
completely took care of the problem.
Red '96 4x4 2500 Auto 3. 54, TST #5, Major Pump Mods(By "Scheid Diesel") 370 Diamond B Injectors, Gov. Spring kit, AFC Spring kit, Banks Exhaust, Prime Loc, Cummins Chrome Kit,Psychotty Air Filter, Pro-Torque Converter, BD Valve Body, BD Pressure Loc, Isspro Gauges, Sendel 16" Alum Wheels w/ 33" BFGs
john P , i see in your sig that you also have a vb and TC , from BD , was this pressure lock install before or after those mods ??? you need the valve body at minimum to make the pressure loc totally effective , or a valvebody that has the pressure loc function incorporated into it ... #ad
Mopar-muscle:
I have a "Pro-Torque" Converter and
"BD" Valve Body. I had the "BD"
Pressure Loc installed AFTER the
modifications to the pump and the
installation of the 370 Diamond B
injectors.
Hope this has helped answer your
question.
John_P
