2nd Gen Non-Engine/Transmission BD-Power Turbo Boost Builder ?"s
Engine/Transmission (1994 - 1998) Fuel Leak
Engine/Transmission (1998.5 - 2002) idle rpm range
i got a 2001 cummins with edge drag comp and i seen this this BD-Power Turbo Boost Builder
any 1 know any thing about it??? my truck is an automatic so the wastegate has solid line so u cant just block can u???thanks for any input. . Seth
Is it a j-hook? That is what is used on an HY 35 turbo. It hooks on the wastegate actuator with a spring and turnbuckle to hold it shut longer to build more boost.
I seen the advertisment for that too. and i was wondering what that might be. Looks like a simple wire conector, i wonder if it simply is a dummy wire set up to keep from triggering the ECM on high boost. There adertisement claims "it will increast exhaust volume and boost pressure - plus it prevents over boost trouble codes. "
If i had to bet i would assume its just a resistor for the ECM.
