LHolland said:Thanks all for the input. Nice pics Nicklienonen. I was hoping you were going to show everything back together. Does it move the shifter more towards the driver? Was it hard getting the shift lever off.
Thanks again everyone, sound like something else need to add to my wish list.![]()
JPM said:thanks GENOS,(no word from BD) got the new kit, installed and tested. SAT. The new shift arm/ball had a different finish, it might be made of stronger material(I hope!) Also it had a different bend and seemed shorter. It now interfers with the Genos cup holder, not much ,but more than the old one. But what's really wierd , it shifts so much better. Its alot better than the old short shift arm that broke![]()
CRoth - BD-Power said:Some of the earlier units were affected by hydrogen embrittlement. The newer units use a different coating process, different metal and are heat cured and should be much stronger.
If your shift lever is interfering with the Geno's cup holder, get it replaced again. Mine works fine with my cup smoothie.
