I posted this yesterday in another thread. At the time I couldn't find this one. Pretty much the same experience as you Bill.
Recieved mine Tuesday. Installed Friday, went like this: removed shift tower and laid it out on a bench and switched the parts just like the directions said. Put silicone on both sides of the spacer and put it on the trans, just like the directions said. Put the isolator on the spacer, just like the directions said. Put silicone on the bottom of the shift tower and put it on the isolator, just like the directions said. Put the first bushing in the shift tower, just like the directions said, and down to the metal plate on the isolator where it bottomed out, NOT like the directions said. So I called BD and explained the situation which was new to whom I was talking. He said he'd call me back in 1/2 hr. I started cleaning up all the fresh silicone and finished so 2 hrs later when I hadn't heard anything I said the hell with it and drilled my isolator and dry fit everything only to find the bushings that came with the shift kit are too short. So I called BD back and spoke with the first guy who connected me with the second guy who said "use the factory bushings". Only problem was that since I drilled the isolator they would now do no good. So now I need either a new isolator or longer bushings. By the way, they told me they have revised the kit by drilling the spacer for the bolt dia. and reusing the factory bushings. If I have to spring for a new isolator I expect BD to send me the revised spacer. BD is going to get back to me next week.
Those bushings need to be the correct length. They limit the compression allowed to be placed on the composit shift tower and the rubber component of the isolator. My concern is that if the bolts are torqued to spec, or even close, with the short bushings that sometime down the road that composite shift tower is going to break up and wind up in the trans.
So what do yall think? Am I getting my shorts in a wad over nothing?
Fred
