It looks like you did everything right.
The only suggestion I would have is to maybe have the wastegate start to open even earlier to help get boost under control. The 3rd Gens do build boost slightly faster than most 2nd Gens. On mine, the wastegate starts to open at 10 lbs (actually just a hair below 10), and I still see 67 lbs of boost. If yours is starting to crack at 15 lbs, add in a few more lbs for over spool before the gate can get boost under control, and I can see where you may be hitting 70+ lbs of boost rather quickly.
I tried to make a stand-out wastegate cover for mine as well, but couldn't make anything that worked well while keeping the edges flat enough to still get a good seal. I ended up staying with the dimpled cover and that little dimple only lets the flapper open about half way. I bet the stand-out cover really helps with keeping drive pressures low.
You wouldn't be interested in making another cover and selling it to me would you?
