Ok so heres the scoop. I have the tow twin on my truck and have been fighting an exhaust leak on the flange of the top turbo going to the hot pipe. I contacted bd about this. they said try greas and let it get hot and bake in, then red rtv, then take it all off to a machine shop and have it flattend. I tried all of this with no luck. i even bought a $60 clamp the put on the turbos of air planes that is way stronger then the one bd sends. Still leaking under boost. I feel like BD pretty much gave up on a solution to help me. The answers i started getting were we dont have problems with that leaking. This is just me thinking out loud here. a flange with only 2 flat serfaces seems like an ideal splace to leak with such a small clamp and the amount of drive pressure and heat generated under boost. he leak has made a massive mess out of my truck more then one time. But i am here to tell you after about 6 to 8 months of trying stuff and to the point of just welding it i think i have found a solution! I bought a 3. 5 inch colector gasket and used gasket glue on the top turbo housing and put the gasket on and centeres it all up and let the weigh of the turbo set on the gastet for abour 2 hrs to dry good enough for me to trim the gasket. when i trimed the gasket i made sure to leave some protuding tot he out side so the clamp coudl hopfully stop it from being pushed out. i then put gasket glue on the hot pipe and put the exhause housing in plance and the clamp on. let that try while i figure the restof the install out. it seems to be holding very very well. If any of you with twin turbos have had a problem please post what they were here and the soltuion you found if you have found one. i have look on many forums for ideas and people just dont seem to post on this issue too much. i did find one post but no solution. I hope this reaches someone that it can help!
Johnny
Johnny
