We finally are in production!
The Cummins ISB map sensor monitors the turbocharger boost levels, which can exceed the stock parameters if you have BOMBed your engine.
When you add a set of BD XXX injectors to a engine that has a Plug n Power you need a BOOST FOOLER to keep temperatures down.
The Boost Fooler plugs into the stock Map sensor plug and modifies the signal sent to the ECM When the boost exceeds the stock levels, accompanied by high exhaust temperature or turbo modifications the Boost Fooler will prevent the Cummins Ecm from backing the fuel off.
Engine with just a Plug n Power will experience higher boost levels and cooler exhaust temperatures with the installation of the Boost Fooler.
We have 3 different kits;
‘98. 5-‘00 part # 1055920 This kit has the triangle plugs and includes a flowed waste gate turbo orifice to encourage the waste gate to hold on longer to achieve higher boost
'00-01 part # 1055921 This kit is designed for the HO ISB w/6 speed std. transmission and has a flat plug connection including the calibrated turbo orifice.
‘00-’01 part # 1055922 This kit contains the flat plugs and an X Hook that mechanical clamps the waste gate lever for higher boost levels on the HY35 turbo.
Brian@bd-power
Brian@bd-power
