Bed Divider
Lower control arm cam bolt?
White Knight back-up light
I have been searching for something to divide the bed of my truck and found this on a couple of different sites. I am looking for something to keep things from sliding around.
truck bed cargo gate
Has anyone had any experience with this product?
TIA
Paul
I do not, but the bed has slots on the sides for 2" wide lumber to fit in, I have a couple 2" X 12" cut to the correct length with carpet wrapped around the ends, they work great, on the one closest to the tailgate I have a couple eye bolts that I can hook bungies on so I can hold bottles of trans fluid, fuel treatment, ect... tight against it.
I have one. They work ok, but if you have heavy objects moving around and bouncing against it, it can slip loose. This may be because of my bed liner, but there is only so much pressure a snap lock can make.
I can not use mine anymore because my tonneau cover fits too low in the bed.
PM me if you are interested in a used one.
I did the same thing but without the carpet, I have a spray in liner.
I used a sabre saw & belt sander to round the bottom ends to match the contour of the bed, they work for me.
I have a factory bedliner and a thick rubber mat. Things don't slide much on a rubber mat, however they may tumble. Dividers and rubber mat is the best solution.
