Main cap fretting has become an issue with the high horsepower and torque outputs of the Celect engine, and mostly seen at high miles.
I'm not completely sure what happens, whether it is main bolt stretch, funny torsionals, or what. I do not beleive it is a sloppy original fit. There was a stop gap measure of using loctite on the main bolts but it obviously was not the ultimate fix.
I would think that if Cummins has come out with a bed plate upgrade then it must have been a torsional causing the problem.
This is not unique to the M-11 engine as I have seen it on several high mileage ( I. E. 1,000,000) High horespower N-14s' as well as one NTC444. Anyone doing overhauls on these, needs to be aware of the issue and check all main bearing caps for fretting prior to proceeding. This does not make these a bad product, it is just a new service issue to be aware of. As MR. Miller has alluded to , they will probably not make it out the shop door after new bearings are installed due to reduced oil clearance. -A Johnson
(not the official Cummins answer in any way shape or form)
