Alright guys, need some help. Last year I swapped out my D80 rear for a AAM 11. 5 axle out of a 03 Dodge. (there are alot of reasons why I did this, but at this point that is irrelevant) Anyway, I have had issues with it being kinda squirrly and feeling "loose" especially when its slick out. Figured it was tires or something and said the hell with it. Well after chewing threw yet another set of rear tires (not fully do too my heavy right foot, but somthing else) I decided to do some looking, and pulled the rear shafts today. Drivers side slid out with out issue. The bearing was a little loose, as I could move the hub up and down by hand, so I snugged it up as it should be. Passanger side is where it got ugly, and I figured this was where the issue was due to the wear pattern on the tire (inside edge had double the wear as the outer edge of the tire)...
I had to pry the shaft out. It definately was binding. When I got all the bolts out, the hub bolt holes and shaft holes didnt line up anymore like they normally do. It looks to me like the axle housing needs to go forward 1/8" and down 1/16+". So now I am stuck, what do I do? I cant afford to swap axles again, as well as find one with 3:73 gears... Is there ANYWAY I could straighten it out? When I worked on race cars we would tweak axles (long story) with a torch by heating up the tubes in certian spots to get them to slightly bend the way we wanted them.
Just looking for some wisdom here, any body got any ideas?
