I have a friend that has just purchased a new 20' enclosed car hauler for use as a storage trailer since he & his wife are going to be full-time RV'ers. The trailer is rated at 7000lbs. with 2-3500lb. axles.
He grossly under-estimated the weight of his valuables & the springs were bent in the opposite direction of their original design.
If you look under the trailer, when unloaded, the middle of the axles are "bowed" so that the middle is higher than the outside of the axles.
He has jacked-up the entire trailer & it is sitting on 4 heavy-duty jackstands. The wheels are off the ground, now. The springs have returned to their original shape but, the axles still have a slight "negative" bend, to them.
He is trying to get rid of some of his valuables to get the trailer weight to where it should be & what it was designed for.
Does anyone have any experience with problems like this. Are the springs permanently damaged? Can the axles, somehow, be bent back to their original shape or are they permanently damaged?
We looked into upgrading the trailer to a 12,000lb. rating. Springs, axles & 16", 8 hole wheels with load range E tires. Would cost $1500-1700 for this upgrade but, the frame is still rated for 7000lbs. So, this is not a good option.
We would appreciate any suggestions from those with experience with a problem like this.
Thanks.
Joe F. (Buffalo)
Thanks.
Joe F. (Buffalo)
