Originally posted by 2ndgen2500
what is the best? is there any advantages to getting one of those ram induction (or whatever they are called) or should i just stick to an in the filter?
First, don't waste any money on any kind of drop-in filter with the stock filter box. This box is designed to allow enough air into it for a paper filter. Any high flow filter will just use a smaller portion of the filter because the airflow is restricted by the box. I had a K&N filter in the box and one month after I cleaned it I took it out and only the center portion of it was dirty. What you need to do is allow more air to get to your filter.
Second, you need to look at how filters are designed. There are two basic ways to increase airflow. One way (the best way) is to increase the surface area. The other way (the worst way) is to have larger "holes" for the air to pass though. Naturally this also allows larger particles to pass though the filter as well.
Everyone keeps trying to come up with a new and improved way to filter the air you breathe and the air that your engine breathes. Let's face it, how else are they going to get you to give them your hard earned money? It always comes back to the fact that a paper type filter that you throw away does a better job of filtering. I'm in the HVAC business and nothing keeps the ducts in your house (and more importantly your evaporator) cleaner then a pleated throw away filter. All of these reusable filters do not stand up over time and you can never get them completely clean.
Now take your truck filter. These high flow filters compromise filtration for flow. How else can you explain one cleaning in 80,000 miles??? Where did all of the road dust/dirt go? Where did all of the pollen go? Even filters in hospitals, which are much cleaner then our roads, are changed several times a year. I agree that the air that is filtered for our engines does not have to be as clean as the air in a hospital but I think that you can see my point. A high flow filter will allow much more dirt into your engine then a paper type filter will.
I have concluded that the BHAF is the best of both worlds. It filters much better then the high flow filters and it makes up for the lower flow by having a very large surface area. With the large surface area and the deep pleats it should also have a long life. At $40 apiece you can buy quite a few for the price of one of these "canons" and put a lot less dirt into your engine.
These are my thoughts on the subject and why I dumped the K&N for the BHAF. BTW, when I switched to the BHAF my hwy mileage increased by 1 mpg. I contribute that to allowing more airflow to the filter since the BHAF didn't have that restrictive box surrounding it.
