Details here: TDR Privileges
Whats the best fluid for my transmission??? I have been using AAMCO fluid I get at Auto Zone, what do you guys recommend?? and where can I get it??? Thanks, Willie
I use ATF+3 type 7176 in my '95. I'm sure the '92's have a slightly different trans, but I'm convinced if I run anything ELSE in my trans it will go "ka-blewy"
Check with your Owners Manual. ATF-3 costs $$$$, but if it keeps my trans healthy I'm going to use it.
I am using amsoil atf+4. Don't know how good it is, but it is working in my transmission. It is amsoils fluid for Chrysler transmissions. The Amsoil universal also works... ... Bottom line, anything that meets chryslers atf+3 rating. How much is your transmission woth to you????
