Best BIG mud flaps??
PRETTY GOOD AMSOIL DEBATE
Evans Waterless Coolant
Going to Alaska this summer and absolutely need the biggest mud flaps I can get so as not to beat the *&##% out of my trailer!!
Camping World has some, but have any of you any experience and preferences?
Thanks
2001. 5 2500 SLT+, QC/LB 4x4, ETH, 6spd, 3:54 LSD, camper/tow equip. , NV241HD, Bright Silver, Snug Top, Ispro w/3 pod pillar w/tweeter, Pyro, Boost & Mag Hytec cover w/temp guage, "Plain Wrap" (no decals or emblems)
Try any of your local truck outfitters or hit a heavy duty truck dealer (Mack??)and grab a pair. Definitely worth the effort gettin em on before hitting gravel.
J-eh
Jason Hoffman
Lil' Mack - 89 D250LE 5 Spd 3. 54 LSD Reg Cab. K&N,"tweaked pump", BD Injectors, Banks Pyro/Boost, 3. 5" Exst tail section straight. E&M Custom seats. Bosch H4, PIAA 80W/80W HdLites. 100W Drv,55W Fogs.
237,500 miles (380,000 Kms) 7850 Hrs. Cummins Power Booster member.
The Original Turbo Diesel
Lil' Mack Pics 07-00
Try Northwest custom, I've got a pair on my truck. I get a lot of compliments on the looks and they work great. See TDR links page for the http link.
1997 2500 Ext Cab 4X4,5 spd,3. 54's,Pac brake,Rancho 9000's,Centerforce clutch,K&N airfilter, Isspro gauges,TST #11 plate (280hp/680tq),AFC medium spring, Jardine 4" exhaust, 370 Diamond B marine injectors and 16cm turbine housing.
Rebel,
I looked for Northwest Custom and even search for it. Am I blind or can you tell me were to find the link.
2001. 5 2500, quad cab, 4X4, ETH/DEE, 4. 10 LSD, 255/85 BFG MT, Leer topper, Piaa driving 510's in bumper, Line-X, Stereo= JVC KD-MX3000, MBQuart 6. 5 components in front doors, 6. 5 coax in rear, JL Audio Stealth Box sub in center seat, Fosgate 400a4 and 250a2 amps, DynaMat everywhere
Northwest Custom is the only way to go!
<A HREF="http://www.omnicast.net/nwcustom/index.htm" TARGET=_blank><font color=red>Northwest Custom</A></font>
[This message has been edited by BIG BOB (edited 02-22-2001). ]
I have the stock "pre formed" dodge ones but I modified them. If you look at them, there 2 pieces, you got the molded piece and a flat piece of rubber/plastic that screws to it. I replaced the flat piece with larger ones I bought from PepBoys. No more crap up the side of the truck from the front or back tires. NOTE: on my 98, the exhaust has kind of warped the rear one a little. and I have them low enough that if you bottom out the front wheel, the flap will drag a little on the road, but that don't happen often.
Our local Peterbuilt shop has tons of different flaps, real cheap. #ad
I tow a 5'er & use the trailer hitch for the mud flaps. I bought a piece of 2" box without the ball & welded on 1/2" angle iron long enough to extend a couple of inches wider than the bumper. The flaps hang from that with stainless fasteners & the angle iron is painted to match. They stick out wide enough to catch all the rocks from the tires & go high enough not to let stuff slip thru between the bumper & the top of the angle iron. They are 24" wide & I had to cut them down a little as they were pretty tall. #ad
Money Sink - 96, 5 speed, TST 380, HX40-16, 300 HP Injectors, Scourge BD 4200rpm Governor kit, McLeod, 4", CATless, straight out back, chrome turn down, ISSPRO Pillar, Delvac 1 & Amsiol, K&N, Mag-Hytec, 3:54, Michelin 235s on Alcoas, Rancho 9000's, Valentine One.
Dutchmen 27' 5th Wheel.
GoldWing.
I don't have mudflaps(just the Mopar splash guards),but the most awesome mudflaps I've seen are from Northwest Custom. I'm not a flap kinda guy,but these are so attractive looking I may eventually get a set.
-Mike
I have a set of real nice CAT mudflaps. They are white with black lettering, and I hand painted the "triangle" Cat Yellow.
If ya want I can measure them and tell ya how big they are but they are pretty huge... . if your interested.
Mounted an "Ultra Guard" mud flap using angle iron to the bumper before travelling the Forestry Trunk Road last summer. We carry our mountain bikes on a hitch mounted rack, and there were no problems from the gravel or mud. I wish I could say the same about the dust though #ad
Needless to say, we are looking at the possibility of "bagging" our bikes before we venture onto gravel roads again.
Doug
91. 5 D250 5 speed, 16cm2 housing, gauges (EGT, boost, tach), BD exhaust brake (w/ 60lb springs)
[This message has been edited by Doug (edited 02-25-2001). ]
Bought mine from Cummins store. They have the Dodge and Cummins logos on them. The store URL is:
http://www.powerstore. cummins.com/
2001, 3500, 2X4, QC, SLT, Auto, 3. 54 gears, camper and tow packages. Lance model 1130 camper. Rancho 9000 5 Speed shocks. BD Brake, autoloc, pressureloc. Hadley air horns. OEM bugshield w/eyebrows and dash cover. Member San Jose Ram Runners.
46wdx,
The price for Northwest Custom Mud flaps is per pair. I know there are a little spendy, but you won't find a better looking or better quality mud flap anywhere.
..... ditto that BIG BOB!
I sure like mine! #ad
John Treibel
'98. 5 2500 QC 4x4 Sport, Glasstite Vision II, 285 BFG A/Ts on M/T Challengers, Warn 4X Boards, Mopar fender flares & tow hooks, NW Custom s/s-rubber mud flaps and accs. , Mag-Hytec diff. cover & trans. pan, Edelbrock IAS shocks, Reese Titan V hitch, SPA gauges (3), Dynamat, '00 Sport grille and headlights/PIAA Super White bulbs, PIAA Dual Sport 900 aux. lights, BD exh. brake, Amsoil Dual Remote Bypass, Optima Yellow Tops, DD3s and DD TTPM, Aeroquip AQP braided s/s fuel hoses, Banks High-Ram intake manifold and 14 cm2 turbine housing w/Big Head wastegate actuator, ATS 3-piece exh. man. , Banks 4" dia. s/s exh. sys. , DTT 93% TC, DTT custom tuned VB, BD modified trans. front pump (enhanced by DTT), Air Bulldog induction hood (with NACA ducts), plus MANY other trick modifications
I got mine at a fleet store. I custom cut and fitted mine the way I want them. The front one are about 3 1/2 inches from the ground. The rears are about 5 to 6 inches from the ground.
READ ALL THE OTHER CHEAP PLACTIC FAKE
FLAPS, THEN GET THE BEST THE REAL ONES.
NAPA HAS REAL BIG RIG METAL HANGERS FOR 10. 00
EACH SIDE ,MAY HAVE TO BEND ALITTLE TO FIT
IF OVERLOAD SPRINGS MY 93 DUELLY THEY WORKED
GREAT NOTHING IS HUNG OF TOUCHING FENDER
THEN BOT FROM TRK SUPPLY CO REAL 2' WIDE
RUMBBER FLAPS CUT INSIDE ALLITLE TO CLEAN
LEAFS, THEN FINISHED UP W/ REAR BIG RIG
CHROME FLAP WEIGHTS. TOTAL $$$ 45. 00
COMBINED , COME MONE YOU GUYS GET
THE REAL STUFF I HAS NOT HAPPY LOOKING
AT SITES OR ADS W/ 200. 00 FLAPS
OR 100. 00 PLACTIC ONES. FOLLOW MY ADVISE
MAKE EM ONE TIME WHEN RUBBER GETS WORN
THEY COST 8. 00 EA OH ONE MORE ITEM
RUN VERTICLE METAL STRAP FROM BOTTOM MIDDLE
OF FLAP WEIGHT TO TOP CROSS BAR KEEPS
FLAP FROM MOVING TOWARDS TIRES WHEN BACKING
UP HILLS , IT WORKS GREAT!!!!
GOOD LUCK IF IAM TO LATE
OTHERS TAKE NOTE YOU WILL BE GLAD YOU DID.
BILL
1993 w350 ex cab, banks,nv 4500 in
open exaust, pw Injectors are in. Big rig flaps,tach in,. Its loud and goes ok, for a 93,Ham radio Call KK6dm
has ability to communicate any where in the world. Headliner shelf
5 antenna's
