Best Boost Module/Fooler for ETH?
exhaust brake purchase
Muth Signal Mirror Install
I am helping a buddy with his new H. O. , and I don't have any experience with these things. He & I have agreed that injectors (for the pump's sake) are the best modification, but only if used in conjunction with something to allow more boost. Who makes the best/simplest boost module/fooler????
98 QC 3500 4X2 ISB 5-speed; 10-level Competition PowerMax; DD Stage II's; 4" exhaust turbo to tip; Luk ProGold; K&N; Amsoiled; Pillar Mounted Boost & Pyro; etc. , etc. ,
Depends, if you plan on adding a VA then check out the EZ for the simple fact there is a boost module built into it already! With the VA you have to buy a seperate boost module.
However if the only thing your after is injectors and a boost module then I would say Practical solutions is the way to go.
He is not interested in running the VA or any other fueling box. These have reduced effectiveness on the ETH. The decision has been made to run only injectors and a boost device, provided that such a device can be used without leaving "evidence" of bombing such as nicked wires, etc. I would think that someone makes a boost device which plugs in to the MAP sensor on the ETH. But as I said, I have no experience with these H. O. 's. Also, I believe the ETH has a different wastegate setup, so the popular "boost elbow" does not work on it either.
The EZ and VA are not "classified" as major fueling boxes. They provide minor fueling (compared to the major fueling boxes such as PowerEdge, PowerMax, BlueBox, JVD, etc) They provide timing enhancements that work rather well on and ETH. Just something to think about.
i have an ez on my eth and i will tell you it works great. i also have the void stickers and the ez hooks up so that you don't bother them. the ez is not a fueling box it's more of a timing box with a built in boost module. the ez also comes with the boost elbow to decrease smoke with the addition of injectors. i am currently looking to add dd2's to my truck and we will see how long the clutch will hold #ad
i am getting my truck dynoed today and i will post the results.
2001 eth ez box and more on the way
