Best brake shoes for 2500?
ISB Torque at Idle
Hot weather = smokey DD2s
What have you used and how have they worked and lasted, I have a leaky rear seal and need to redo the whole thing back there. What about front pads? best results?
TIA
John
97 SLT Laramie CC 5spd, 3. 54, Ranch Hand front and rear. Gauges, EGT, Boost, fuel pressure, oil temp,indash CB, custom switch mount-6 switches BD brake extra fuel tank 45gal. Oh oh dang cat fell off, took the muff with it. Member NRA/USPSA
John, Get yourself some Raybestos Super Stop brake pads. They are a fleet duty pad that work extremely well with our trucks. They also have rear brake shoes as well. Keep those rear shoes manually adjusted every oil change. Since your going to have everything apart anyway, head down to NAPA and get yourself a set of 3500 rear wheel cylinders. I've tried Mopar pads, they suck. Performance Friction Carbon Metallic pads, stopped great but didn't last too long (22,000 miles). Super Stop pads still looking good with 37,000 miles on them. -Glen
1998 12 valve 2500 Quad Cab, A/T, 4. 10, Deep Amethyst, 4. 5" Skyjacker Double Flex lift kit, 36. 0"x14. 5"x16. 5" TSL Super Swamper radials on 16. 5"x9. 75" Weld Typhoons, Speedliner spray in liner, Raven high rise cap, J&J stainless steel Nerf-N-Steps, 4" Jardine exhaust, 370 HP Diamond B Injectors,JRE #3 plate, DTT VB & converter
I'm with Glen, the Raybestos shoes have been great. I used the PG Plus (I think that's what they were) and have been very happy with them. I did not install the 3500 wheel cylinders, but wish I would have now. Oh well maybe next time.
-Ryan
Can you guys tell me if the wheel cylinders will be a direct replacement? Can you also tell me where to order the raybestos shoes from.
Thanks
1998 2500, 12 valves, SLT, auto, 3. 54, 285/75-16, TST 230/605, t/c switch, DiPricol EGT/boost guages,K&N,camper special, 65,000 miles(2/01),
12 ton goosneck!
'01 Polaris EDGE-X 600
Red Rocket
The wheel cylinders bolt right on from what I have been reading and the Raybestos shoes are a stock item at Pepboys as are the wheel cylinders for $11. 99 ea.
