Mobil1 & Amsoil have the highest 1st pass efficiency ratings.
Mobil1 (I use M1-403) is rated for 5x's systems normal operating pressure & is available at AutoZone for $9. 97 These filters can filter all the way down to 10microns.
Wix & others are good filters but only filter down to around 25microns. Why do Wix & others do so well as compared to the higher rated one's? Thats because;
(From NORIA)
> * Smaller particles (less than 10 microns) cause the greatest
> engine wear.
> * OEM filters are designed to trap particles down to only the
> 30 to 40 micron level.
> Let us first step back ask the question of how does wear particle
> contamination finds its way into the crankcase? We have found
> that we can categorize these sources into five major entry
> points:
> 1. Manufacturing Contamination: wear metal debris remaining
> after OEM or rebuilding machining and assembly.
> 2. Operation Contamination: wear metal contamination particles
> generated under normal running conditions.
> 3. Lubrication Contamination: particles exists in both new, as
> well as, make-up lubrication fluids.
> 4. Ingestion Contamination: particles ingested through oil
> breather caps, seals and blow by past piston rings.
> 5. Combustion Generated Contamination: soot contamination is
> formed as a byproduct of the combustion process. It starts as a
> sub-micron sized particle which then conglomerate together with
> others to form a major wear component.
> "As it turns out, it is this last item, combustion generated
> soot, that is the primary source of the problem. Traditionally,
> soot in diesel engine oil has presented our industry with the
> difficult challenge of successfully and economically measuring
> particle contamination. We will discuss overcoming this barrier
> later in this article.
> WHAT LIFE EXTENSION OPPORTUNITIES ARE THERE FROM
> CONTROLLING DIESEL OIL CONTAMINATION?
> "Over the years, it has been our experience that with an
> aggressive four point contamination control program your
> ability to double or triple diesel engine life is an attainable
> goal.
> "How is this possible? First some background on the subject.
> Oil contamination particles are present in diesel engines from
> the sub-micron size to particles exceeding 40 microns. Today,
> most engine manufactures continue to install and specify filters
> that are designed to be effective in controlling wear particles
> at only to the higher 30 to 40 micron levels.
> "It is critical to know that extensive laboratory analysis and
> field studies confirm the fact that 0 to 10 micron sized
> particles cause 3. 5 times more wear than particles larger than
> 10 microns! This fact may sound backwards until you consider
> oil film thickness. Major wear is caused by these smaller
> micron particles because they can enter and compromise the
> critical oil film thickness layer that separate the moving
> parts in your engine such as rings, rods and bearing clearances
> typically designed and engineered to these very same 0 to 10
> micron ranges.
So how do you get out those 0-10microns particles?
1) Change your oil regularly!!!!!!!!!!!!!!!!!!!
2) If you can justify the costs go w/ a bypass system
Considering this empiracle data, going w/ a high eff synthetic fiber filter
might not give you such a good advantage over just a "good" quality filter like a Wix, since neither gets out the particles in the 0-10m range anyways.
But IMO it can't hurt to go w/ the better filter if its cost effective, so thats why I went w/ the M1.
BTW, IMO that filter cutting open test published in the TDR was ridiculous.
I've seen it in a motorcycle mag & thought it was ridiculous then.
Can you cut open a tire & ascertain how it will perform?
No one can tell how a filter will perform by cutting it open.
WOT!
One could only ascertain the very poorly manufactured filters like Fram, but nothing else.
Pleaseee...
Mike
