Engine/Transmission (1994 - 1998) best head gasket
Engine/Transmission (1998.5 - 2002) vac.pump
2nd Gen Non-Engine/Transmission Tire Siping
I am running a silver bullet phat shaft 66 waste gated at 40 lbs. 140 ddp injectors with 12mm head studs. I am going to run the stock pump turned all the way up. What would be the best head gasket option besides fire ringing it?
What I've been reading is the factory gasket is the one to stay with and studs, which you already have. I went with . 010 thicker, pleased so far.
