Who makes the best HX35? I'm looking for the fastest spool up, the most durability, and the lowest EGTs. If there is a better alternative, i'm also interested.
Here is some information on what my truck has as well as what i have planned for it. My second WH1C seems to be on its way out and i need a replacement, hopefully one that will last more than a few months. I have a lot of fuel, but am trying to plan compounds with an HT3B i already own. The first turbo was ruined by having it ported. The one on there now was sold to me by a shop that had it in their junk pile and told me not expect a year out of it. I've gotten 4 OK months out of it.
The truck weighs 9,600 lbs with one extra passenger. Modifications i have planned will someday put it well over 10,000 lbs. The engine compartment has less room than a Dodge so i may have to mount the big turbo above the exhaust manifold. I don't mind clearancing the hood and there is probably enough room as is.
When my original turo was ported, i had far less smoke on the bottom, higher EGTs, and could rarely get boost into the mid 20s. Before it was ported it made 42 psi, lots of smoke, high EGTs, and way more power. Having it ported did everything opposite what the guy guranteed, he never returned my phone calls.
When i put the current used turbo on, i had more smoke on the bottom and saw mid 30s for boost. Also got the best fuel economy so far, 15. 9 mpg. That lasted only a couple months. The neck snapping take off has reduced and now feels like i'm taking off in 2nd gear. There is very little smoke and often no boost showing while cruising. EGTs are also higher.
I don't understand how a turbo that is not working well will have less exhaust smoke, but that's what i was told by the shop where i bought the current turbo. I've found no boost leaks and it seems to be getting fuel. I figure that if i have to replace my turbo again, it is probably time to upgrade so that i can handle the amount of fuel i'm using.
From reading posts and talking to some who run compound turbos, it seems a single turbo could never give me the instant spool up i require for my constant stop and go city driving, and the big air needed for charging up mountain roads.
Piers told me their mathced compressor wheel and housing will spool quicker than a factory turbo and that it would be perfect with my HT3B. I wonder if, since i'll be running compounds, would i need to run a modified HX35, or just find a good used replacement? I've read posts about losing spool up with this setup and that is a huge concern.
I would like to stick with the 12cm turbine housing if that is the fastest spooling possible. If i decide to spend money on a turbo that spools as fast or faster than stock, which brands and models should i consider?
