Best II injectors
Smarty and p0633?
tst pyro and dipricol reading different
I am leaning towards II for a set of injectors…
I would like to know if I should contemplate others. I want big H. P. done right and have the means to get there. I do tow, boat, 5th wheel and plan on twins in the near future.
well you got the right company, II offers amny different levels of injectors you could use but based on what you said i would reccomend a towing set( you could allways do more as well)60hp, they offer 60-200+hp for common rail. quite a few guys use them with very good luck. i know im very happy.
I have I. I. 150hp dragon flows & let me tell you... Brady has got his ---- together. They idle smoother than stock & don't smoke at idle. I love these injectors, but they tend to blow some soot @ low boost. :-laf
I would ask that you research and consider F1diesel injectors.
In the end you will mostly have people running one of 3 injectors:
I. I
F1 Diesel
Dynomite Diesel
I chose F1 because the tip is a custom tip that is a different material made to withstand 40k lbs of pressure. No cracked tips here!
can somebody post a link to II. I'm new to the diesel world and don't know the company y'all are talking about. Thanks.
If you want big power, go with F1 Diesel!
I know a few guys who had II injectors that have now switched over to Don's injectors... .
I haven't ran the flux or II injectors, but I do have the Dynomite 90's. I like them a lot. They added a considerable amount of low end power, and no added smoke to speak of. Cruising and wot egts up about 100*
