MStaggs said:
Thanks Jay!
For me, its my daily driver AND I tow an enclosed trailer on race weekends.
SO basically I am looking for all around power AND civilty.
Side note: I purchased the boost, egt and trans temp guages you recommended. Where can I safely install the trans temp sensor on the 48re?
MStaggs. could you fill in your sig w/ your truck info. It's helpful to other users when answering your question.
I can't help ya on where to install the transmission temp gauge, being that I have a six shooter. There has been alot of discussion of where to install. Best advice I can give ya, is ask, research, call the major transmission players (ATS, DTT, Blumenthal's, BD, Goerend) and then decide for yourself.
Adding usable power to tow without getting egt's too high can be a challenge without spending $$$ to change alot of other things.
Rather than naming the brands, perhaps an understanding of how boxes make power will help you decide. Basically you need more fuel and air to get power.
To add fuel you either a: increase duration of injection, or b: increase the pressure that the fuel is injected at. Or you can do both. Timing advance helps with fuel mileage and cooling egt's. A lot of people including myself (I'm chicken) do not wish to raise fuel pressure. Others have no issue with it.
If I were to do a box on my truck it would be one that does duration, timing and boost fooling. My truck has a boost limiter that begins to defuel the truck if it sees too much boost, it cuts power
If your gonna add power and tow with an auto, you need to understand the ramifications of doing this. Your auto will only take so much power before bad things happen. Even moderate power will have effects on it. Too much power to a 6 spd will cause bad things too.
Doug Leno did a killer write up in TDR issues 47-49 about adding power to the 03-04 305/555 motors. Basically what he says is that there is a small amount of room to add power before running into issues. The stock turbo is good to about 24psi of boost, beyond that the charge air gets too hot. Putting a full 4" exhaust helps alot too. Eventually you need to think about a bigger turbo, and intercooler. It boils down to how much power do you want vs. how much you want to spend vs. how much you're willing to risk damaging the truck. I think you can make decent power for several hundred bucks. But to make decent power that is really usable, especially when towing you almost have to think about a turbo, intercooler, and exhaust to cool off egt's and keep charge air temps down. With an auto you need to consider other mods to it as well. Many suggest doing the transmission upgrades first, and this is not bad advice at all. Pay now or pay a lot later. So how much of your money have I spent???
Jay
p. s. welcome to TDR
