Chief USA
I am changing out the lube oil in my wife's HO/6spd. truck and I have a 5 gallon pail of Pennzoil Syncromesh that I am going to use this time to flush it out good. The oil that came out looked clean but smelled pretty well used.
What is the best lube oil for this application that meets the MS 9224 spec. for this transmission and who has the best price for a 5 gallon pail?
I have gone back and reviewed a TON of previous old posts on this subject and it appears that Royal Purple Syncromax is the most popular synthetic lubricant. Is this still the case? Any other better lubricants out there that work better???
I just bought the truck with a little over 122,000 miles on it and I think this is the original oil I drained out. The transmission seems to shift very well with the exception of 3rd to 4th gear shift. If you rush it too much, it will not shift and the syncro will reject it with a little clashing. If you shift it nice, slow and easy, it goes right in. I am used to shifting my 2002 NV5600 which seems to shift a bit different so it might just be operator head space and timing.
Just wanted to try changing out all the fluids and see if this help improve shifting so my wife can drive it. She has never driven a 6 speed but can drive a manual trans. car so I may have so driver's school training to do.
If I can fix this 3rd to 4th gear shift issue, I think she will do just fine.
