?Best plate for towing with bombs?
Why does my truck only kick A in 3rd gear.
Found a black wire ending with an eyelet
Have a ground stock plate and want to change to a better one for towing. Have 370's,3k gsk,16cm,4"with 5"stacks,etc. , and I haul heavy. What #TST???????
Drawson is right, the 11 is a good plate for that, EGT is controllable with right foot, clutch will work ok depending on load weight, mine worked fine towing with no slippage but empty at 1800rpm when boost hit 30lbs in 4th and 5th it would slip under full throttle. I never used full throttle towing (didnt have to) so no slip. Trailer is 6500lbs.
