Competition best price for .093 straight lines & crossovertubes (24v w/p-pump)
Competition Stupid and Strange Pulling rules:
Competition ATS wide flange manifold
There is no crossover tubes or injector return lines on a P-Pumped 24v truck. The fuel is returned through the head and exits at the back. Most any of the bigger diesel shops can make or get the lines you need... ... Andy
the tubes in the head that seats line to injector body
also I want the lines straight so I can bend them myself to work around a custom intake I made for the head. So far $47. 00 each is best I found.
There are crossover tubes in EVERY 24V head, regardless of whether or not it has a P-pump. If there were'nt, you would be spraying fuel everywhere and probably not (taking a WAG here) making a whole lot of power. You are right about the lack of return lines and how it exits the rear of the head. You should be able to score those . 093 tubes fairly cheap, meaning less than $150 for a set of 6.
-Tom
Tom. .
Thanks you for the correction and this properly valved owner needs to steer clear of anything to do with those over-valved motors,its probably safer that way.
When I made a call today to check and see just how I DIDN'T have my thinking cap on when I flapped my piehole all I could do was go. . doooohhhhh. One thing I did hear when checking on my brain fart was that the size of said tubes didn't affect the HP/TQ.
And they say old dogs can not learn new tricks... ... . Andy
