Details here: TDR Privileges
Although you can find a 16 CM housing for $150, once you factor in shipping from another place you'll only save like $5-10 so I'd just order both from TST.
You should look into the torque plate from TST also, more power to gain than injectors. A number 10 plate alone on a bone stock engine will take you to 330 HP. I'd look into a turbo upgrade rather than the 16 CM housing though, the stock turbo doesn't like much more than 350 RWHP, you may get 400 out of it with the 16 CM housing but it's better to upgrade the compressor as well. With that much fuel you're EGT's will be hard to control especially with the 370 injectors. I'd got with a phat shaft 62 or HTT's HX40.
