Details here: TDR Privileges
What Is The Best Programmer (box) For A 2006 With An Auto? I Don't Want To Do Anything With My transmission, How Much Will The Auto Take Before Needing Upgrades 30hp 60hp 100hp?
You will probaby get a lot of opinions, however, since you asked, my recommendation would be ( assuming you will leave everything stock) is the Edge w/attitude monitor & pillar mount. That kit will safely take you up to 100hp. YOU don't need gauges, easy to install, has so many features, I can't describe them all. It also has things like turbo timmer, safety alarms, for over boost, egt's, trans slippage, and on the fly adjustibility etc. Also up gradeable if you decide to do fueling and transmission up grades later. You can find these as low as $650. 00 to $900. 00. Shop around for the best deals.
Like anything else, even at stock, you can ruin your auto trans. However, with good driving practices, and no hot rodding, your stock auto trans should be "ok" up to 100 hp increase.
Ditto what HeberRam says. The Edge has a lot of safety features to keep you from burning up your engine and transmission. Just don't get the Hot upgrade if you are wanting to keep the stock transmission.
