Engine/Transmission (1998.5 - 2002) Best transmission jack
Engine/Transmission (1994 - 1998) Trans fluid leak in mountains.
I have used 4-ton floor jacks before as transmission jacks, though they often leave something to be desired. I have also used serious truck transmission jacks, but never to remove a transmission and transfer case together.
I consider looking for a transmission jack, so I have one whenever I really need it. My truck is a 2001 with the 6-speed, but being prepared for other configurations is good, too.
What do you feel is the transmission jack you would choose if you could? I am meaning a jack for use on the floor, not a jack for under a lift.
Are you fabricating any pieces to allow the jack to better engage with the shape of the transfer case or transmission? Are you typically removing the transfer case first, and then the transmission?
I would rather look for a good jack at my leisure, rather than make do when a crisis comes.
I am interested in your thoughts. Thanks... .
The balance point of a 6 speed with transfer case is about 2/3 from the front. What the actual weight is, I have no idea, but I don't think it is over 400#.
After having done two trucks, and several cars, I can say that you want a jack that lifts straigt up and down, has the adjustability to tilt and piviot the transmission, good side brackets (NV5600 is skinny with a round bottom and is a ***** to reseat if it rolls over) and has swivel casters for all 4 wheels.
This would be good
http://www.harborfreight.com/cpi/ctaf/Displayitem. taf?itemnumber=39178
Or this, but it does not lift straight up.
http://www.harborfreight.com/cpi/ctaf/Displayitem. taf?itemnumber=91020
