Best Turbo for 550-600 hp
Aftermarket downpipe?
Which Valve Body should I buy and why
Hey guys, I'm new to the TDR, and I have a question. I was wondering if anyone has had any problems with the HX40 turbo. I know that the HX40 is just a HX35 with bigger wheels and people say that they are weak. Has anyone ever broken a shaft or wheel on an HX40? If so, what kind of boost was it showing when it snapped. I keep mine around 40 psi. One last question, if the HX40 is a bad turbo, what is a good budget turbo. I was looking at a S300 or S400, I just don't have any experience with them.
Thanks in advance,
Rob
I have blown four HX40s over the years. In no case did I run them over 40 psi boost. Generally, the shaft breaks and the wheel and shaft roto-rooter the down pipe and end up at the muffler, inside the exhaust pipe. I wouldn't use an HX40 in a performance application, period. Of the turbos I have used, I would lean toward the High Tech 66/71 with 14 cm2 exhaust housing. Exhaust gas temperatures will probably be high under full power, but spool up and general performance will be good and durability will be good.
Thanks for the info. I only installed the HX40 because I got a REALLY good deal on it. Brand new for $267. 00. I was pushing the HE351 way past the efficiency point with 53 psi. I probably can't find one of those HTs for under $1000. 00 One other thing, I do have the Six vane compressor which is the 60mm compressor and the exhaust housing is 16 cm2. I still have the stock one just in case, but I'm thinking it will look good on my 4BT.
