Cold engine:
1. Start with tow/haul on?
2. Keep RPM limited to what?
Jim,When I start mine depending on the ambient air temp. I will wait until the grid heater light has turned off. Then start, turn cruise control on and set high idle to 1100 RPMS. Wait at least two to three minuets before backing out of the drive way or moving, maybe even more time if it is real could. I watch my oil pressure to ensure that I am in the normal range for my truck, before moving.
I used to turn on the Exhaust brake but not any more, the exhaust brake will not help to heat the engine any more now.
I then drive some what slow until the fluids start to move and I have gone at least a mile or more. Manually shift the auto trans, staying out of 5 and 6 gear, keeping the engine at 1500 to 2000 RPM'S during the warm up period. By now the truck should be good to go.
Sag2,The best way to warm up the engine is to start it, wait for the oil pressure to come up, and then drive it normally. Use common sense, if it's 50 degrees wait 5 seconds and go, if it's 10 below wait another 30 seconds and go. Idling does not build heat quickly in a diesel, so the quickest way to build heat is to drive it. Idling does not improve the lubrication. As soon as the pressure is up and oil has the chance to reach the end of the line (common sense, temp and viscosity) your just wasting fuel and probably washing fuel past the rings from incomplete combustion from low temps.
I'd rather avoid bypassing the filter, so what is the RPM limit of which you speak?There is an oil pressure relief valve, just like most engines. It blows off and returns excess pressure to the crankcase. It will only bypass when the oil is very cold, and the engine RPM is high, and that's it's job, so no you don't have to do anything special, just drive it normally.
Jim,
I'm confused about the cruise control statement. You seem to indicate that you can set the cruise control to a certain RPM without moving. I thought cruise control only worked at a set speed. ??
