No, do what works. If silicone does the job, great.
The OEM putty tape on most RVs isn't butyl. I'm not sure what it is, but it acts like some sort of really fine clay material that's been mixed with oil. That junk dries out, shrinks, and leaks. The garbage putty tape that I've seen is a buff to gray colour, depending on the manufacturer. Real butyl tape is usually bright white, but it can have other colours produced for special applications.
I suspect that a slide-in camper may be a lower vibration application than a travel trailer. All I can draw on is experience. For example, I had a 1989 Yukon travel trailer by Fleetwood that was assembled with putty tape. Within five years, the putty tape had dried out, shrunk, and caused bad leaks and rot. I currently have a 1996 Play-Mor that was assembled with butyl tape. So far, no leaks I have found and the butyl tape is still supple.
The climate here is nasty, and if something will shrink and leak, it'll happen here. 119F, 7% humidity and direct sun take their toll.
Your mileage will, of course, vary.
