Better handling with new 2" Rancho Lift kit & trailing links !
Muffler Choice-Towing, low noise, reasonable flow?
Which gauges to use?
Just a quick note to mention how satisfied I am with the Rancho 2" lift on my 97 4wd 2500. It includes 4 new upper & lower trailing link arms with urethane bushings and spring spacers.
The problem was with 150 k on the rig, the stock trailing link arm bushings were almost shot. An estimate of replacing them was very expensive, like $ 500 labor to remove & rebush the stock arms.
I reasoned that for approximately the same bucks, why not just get the Rancho lift kit with the link arms and pay no more for the upgrade.
Bingo !! Steering and handling response is much improved, vastly better than before. Truck is totally confident in the corners, without that "rubber noodle" front end wiggle I had become accustomed to. I think it's due to a combination benefit of the stronger boxed arm assembly & the less flex in the urethane bushings at the frame & axle mount areas.
Driving in the mountains has been hard on the stock bushings, and this should make it much safer for those challenging roads.
I can't wait to tow the heavy TT soon, it should offer a whole new level of confidence!
Also, had to get longer shocks so I ugraded from the Rancho 9000 to the 9000x, which is now 9 way adjustable. Nice upgrade, also. [I was already very satisfied with the earlier units]
I must admit, the extra 2" [I think it's a bit more than that, actually] of height is a nice thing, too. Better road visibility, and more reason to think it's actually a Pocket Peterbilt
One more thing: there's an Energy suspension sway bar bushing kit on the way, and then there's "Darin's Super Steeering Bracket" that ought to finish out the whole deal... ... ... .
Hope this helps someone... ... ... . Oo.
David
