Since I will have the bumper off, should I put a better trailer hitch on? My 31 Jayco BHS is heavy, but it is paid for. If and when I get up, I will get the scale numbers.
Probably not needed. What is the tongue weight of your trailer?
Here are the weights from my 2 week trip trip last summer, with 3 grandkids, and 2 foster kids, and several grownups.
truck front 4460
truck rear 5160
truck total 9620
trailer 7740
combination 17,360
Depending on how I have loaded all the food, toys, and firewood, I run a minumum of 1280 up to 1500 for the pin weight. I did add some air ride, just because even with the big bars on the E/Z Lift, I was still getting too much dip at the rear.
Hindsight being 20/20, I prolly should have opted for the dually, but I solo alot in the snow, and the SRW does great there.
truck front 4460
truck rear 5160
truck total 9620
trailer 7740
combination 17,360
Assuming you have an electric tongue jack on the tongue of your trailer, use the tongue jack to do the heavy lifting, not your back or a six foot lever bar.
Lower the trailer onto the ball and latch the coupler then raise the trailer tongue (and rear of the truck) with the tongue jack well above the normal ride height.
Attach the spring bars to the link desired for weight transfer and lower the tongue jack. Lowering the trailer tongue and truck rear end will tension the bars as the rig is lowered.
After wallowing out the hitch pin hole and the reciever hole itself opening up a fair amount , I replaced the stock POS with a Titan V Class 5 hitch, haven't even needed the WD bars since either. After seeing how much they are for a 2. 5 " set up , it may be a while !!18k GTW
I read the instructions on this hitch and they are instructing us to drill into the hydroformed frame. I know Reese is top quality, and I'm sure they have researched this, I imagine, but what is your opinion on this?The stock hitch is very nice, but if its starting to wear I would replace it now.
I need to replace mine, it was a little slopy from the factory and that has let it get much worse. The metal seems to be soft. My vertical opening is probably nearing 2. 25"
This new hitch from Reese has been catching my eye. .
Trailer Hitches - Reese
I have not seen a tougher looking hitch!
Did you drill for the installation, and what is your opinion?Seen a couple of the factory ones fail and went ahead a installed a Reese Titan V on my dually when I first got it just for piece of mind.
And the same question for you as well ?????After wallowing out the hitch pin hole and the reciever hole itself opening up a fair amount , I replaced the stock POS with a Titan V Class 5 hitch, haven't even needed the WD bars since either. After seeing how much they are for a 2. 5 " set up , it may be a while !!18k GTW
