Based on the info I have read here, I have decided to buy a set of BF Goodrich A/T KO tires to replace my OEM Michelin LTX A/S which have given me 59,000 miles trouble free. The reason I wish to change is I am tired of getting stuck on level wet grass fields. The Michelins just sit and spin (even with LSD). I am expecting more from the BFG's. I have talked with local dealer and can get a set of blemishes for $170 each mounted and balanced. Steep, but less than the Michelin M/S by $40 per tire and less than the non-blemished by $36 per tire. Hey, a buck is a buck! As long as the blemish is not a slew of profanities or something, He He.
The question I have is the dealer says I can only get an 8 ply tire. "D" rating. That is all they make. I really want a 10 ply like I have but the load rating of the D is still a little over 3000 pounds per tire at 65psi. (If I remember correctly, my notes are downstairs) This is about 400 pounds per tire less than the current 10 ply Michelins, but I don't haul much.
Can anyone confirm that I can not get a 10 ply BFG? Am I making the right choice? I have a 2WD and I do not expect this tire to look like a big Off-roaders tire. It doesn't, does it. I just want a little more tread.
Thanks,
David
Thanks,
David
