BFG 295/75R16 AT's
Did DC fix the 5th gear nut on 98's
Oil Pressure Question
Just had a set installed on my truck today on the factory 8" aluminum rims and they fit the truck just right. #ad
We installed a BFG 315/75R16 on one of the fronts just for s**** and grins to see if they would work. They were very close to working and looked real nice. There was plenty of clearence but the tire would barely rub the track bar on a lock to lock turn. I debated but ultimately decided to play it safe with the 295's. I also picked up some Pro Flaps mud flaps. Very nice and heavy duty but expensive. Need to get them installed ASAP so I won't ruin the paint on the rocker panals with those BFG's.
2001. 5 2500 QC, ETH/DEE, SLT plus, LWB, 4x4, solid white w/agate leather, 3. 55 LSD, camper/trailer tow, 241HD,TT mirrors, 4 wheel disc brakes
Bill,
University, WA. is that next to Spokane, WA? If so we are almost neighbors. If you haven't installed the Pro-Flaps yet, take a look at the Northwest Custom. www.omnicast.net/nwcustom/index.htm
I have Pro-Flaps and I wish I would of known about the Northwest Custom Flaps. I haven't seen any flaps that look better or better quality than the Northwest Custom Flaps! They are made in Rockford just south of Spokane.
"WHITE OBSESSION" 99 Quad Cab, White, SLT, 4x4, 5-sp, 3:54's LSD, Raven cap (cab high), Rhino liner, Stainless Nerf Bars, Stainless Rocker Panels, Tow package, Pro-flap mud flaps with Stainless Cummins "C" add to rear flaps, Valentine One, Uniden PC78LTW CB, Hadley Bully Air Horns, Psychotty Air Induction, Braided SS Fuel Lines.
Things to come;
285/75R16 Cooper A/T's, Pyro,Boost and Fuel Pressure gauges, 4" exhaust system(on the way).
NRA Life Member! (Need to protect our rights and FREEDOM!!)
[This message has been edited by BIG BOB (edited 09-20-2000). ]
Big Bob,
University Place is south west of Tacoma just north of Lakewood. UP just established itself as a city in the last couple of years and may not even be on the map yet.
I have not installed the Pro-flaps yet. I will give NW custom a look. I heard very good things about their products. Thanks
Bill
Bill,
Will the 295's fit in the spare tire area? The 285's I have now fit with only about 1/2" or so left over.
98. 5 2500 QC LB 4x4 5spd, white. BFG 285x75x16
Cummins 24v w/ TST PowerMAX w/EGT and Boost gauges on A-Pillar. VanAaken CPC. K&N In the factory air box. Stock Injectors, Stock Exhaust (complete with rattling baffles in muffler). Re-routed breather stink tube, 2WD-low kit, SnugTop, JJ Stainless Running boards, Tow Hooks, Bushwacker Street Flares, and a Cup Smoothie.
70,000 miles (8/25/00)
Sean,
I don't know if they will fit or not. I did not replace the spare. If I get a flat, I'll just have to put the smaller spare on the rear and drive to the first repair shop. I wonder if DC's roadside assistance includes remote wilderness areas. #ad
Bill, you might want to pick up a spare that is the same size. You don't want to drive with the smaller spare on the rear with the LSD in the rear. You'll heat the clutch packs up if you go very far down the road.
Otherwise, if you have a flat, the spare has to go up front only.
CSCPusher
'00 QC,SB,4x4,Auto,3. 54 w/LSD,Trailer Package, Tow Package, SLT Laramie, 265's
