Bfg 305/65/17 E Rated At Tires
Drive Shaft Vibrations
Spare wheel
Does anyone know if this tire does exist? I searched BFG website and found no info. I did see mention of this size in this forum. Any info would be much appreciated.
I called a local Off-Road shop here in AZ (Desert Rat) and they said the tire does exist. It just as tall as a 285/70, but a little bit wider. Other than that... I cant seem to find any info on BFG's website about this size. And the nearby Discount Tire knew nothing about then either.
I can't find mention of that size anywhere on the BFG site or the big online retailers.
If you're looking for that size in particular, Pro-Comp makes it in a load range E tire.
I'm going to give them a try on the stock wheels and see how they are.
Thanks for the info. Just don't know if I want to go to the 315. My OE BFG 265 Rugged Trails have 71k on them and are still in good shape. I want the equivalent wear and performance in a larger tire. Gonna go with the Kore Recon set up. Any suggestions would be appreciated.
