2nd Gen Non-Engine/Transmission BFG Mud Terrains 255/85-16
2nd Gen Non-Engine/Transmission Tire ?
2nd Gen Non-Engine/Transmission Starter blows a fuse
I am looking at getting a set of these tires and am need to know the actual height of the tire when it is sitting still from the top of the rim to the ground. Also what PSI are you running in that tire.
Also what MPH are you going at 2000 RPMs when locked if an auto or in overdrive if a manual.
Do the tires squirm alot when going around corners and do they bulge on the sidewalls alot.
Thanks,
Doug
I have a set of those on my Ford. Don't have measurements off hand, or RPM numbers (no tach).
They aren't squishy at all. Road manners are just fine. I run 55-60# in the front, and 45# in the rears, unloaded. Same with the dually.
Don't know how much this will help you, but... .
I measured them on my truck about 2 years ago when I was looking for some tall & skinny winter tires.
Front @ 4400lbs axle weight = 32. 9" tall, 10. 4" section width w/ 60psi air pressure on 16x8 stock aluminum 2001-2002 rims.
Rear @ 2250lbs axle weight = 33. 30" tall, 10. 0" section width w/ 60psi air pressure on 16x8 stock aluminum 2001-2002 rims.
Used a digital tape measure which is where the decimals came from.
Dan-
**EDIT** I write down & keep lots of useless information... . sometimes it comes in handy. :) **
