Bhaf options
Failed injectors due to debris in the tank?
Stock turbo PSI???
I would like to run a BHAF on the new '07. Does anyone have some options for a "torque tube" to run with this. I called one of the desert racing companies who used to make one and they are no longer producing them. What have you used? Pics?
Thanks, Paul
I would just make your own... cheaper and works about the same. I bought my filter from tst and put it on the stock tube, works great for me!
In my setup I replaced the plastic baffled tube with a metal one from ebay (~$20) and reused the factory elbows. You can do that or for even less money just remove the baffles from the intake tube.
