In the post over in General not too long ago, I asked the same thing.
Over there someone posted how much air the turbo flows at 36psi. It was something like HX35 = 600 cfm @ 36 psi, HX40 = 800 cfm @ 36psi, etc. But no flow rates at lower boost levels.
Then we have this chart that tells us now much air this filter flows at 1. 5" h2o. But does not tell us the flow rates at 2", 4" 6", etc.
So my question is about somehow mapping pressure drop to boost. I think it would be cool to overlay air flow of the different filters overtop the flow rates of the different turbos flow range.
Maybe this does not make any sense. But I was looking for a way to determine that ( making this up ) the stock filter is good for up to 20psi, the std K&N is good for 30psi, the MoparGuy filter is good for 40psi, the MegaCannon good for 60psi or something like this.
If I never run more than 35psi why do I need to spend $300 ( MSRP ) for a MegaCannon when a $100 BHAF including mount is just fine. But on the other hand I saw at dyno days a BHAF getting sucked down pretty good by the 500+hp dyno runs. Maybe this needs a MegaCannon.
