when installing my bhaf do i leave the factory air filter box bottom in or do i take the entire thing out? got mine in today and man that thing is huge
tp0d said:Take out the bottom of the box, but you have to isolate the 3 mounting studs so they dont put holes into the filter. I used a piece of 1x4 about 12-14" long and slid it under the AC line to keep it there. . Never secured it, as the way it fits, it wont fall out. Been there for 30k now, so i think its workin good heh. .
Make sure to open the filter side hoseclamp -all- the way to allow it to open enough to get the filter on flush. Theres no internal reinforcement, so dont crank down that sucker. Be sure both ends are grease-free, mebe wipe em down with alcohol. Loosen up the turbo side too so you can rotate the hose to get the best fit for the bhaf.
I put a turbo shield on my turbo to keep some excess heat off the filter. Foster truck makes em, stainless, for 20$. Looks good, and keeps more heat in the turbo instead of in the engine cavity. I forget the link, its searchable tho. .
good luck... enjoy that BHAF heh. .
-jerry
ohya, if you havent taken the silencer ring out yet, nows a good time[/
jerry,
Who is or where is Foster truck to get a heat shield?
The stainless sounds like a great price!!!!
Thans, WAYNES WORLD
Did you like the singing turbo!?FANZDSLPWR said:also today i removed the silencer ring with needle nose pliers and a screw driver. today on the way to work i hope to hear her sing. thanks everyone for your help and have a nice holiday.
