I need some help from some of our resident electric experts.
I am looking at purchasing an electric water pump, 108GPM, and 1. 5HP @ 110V or 230V @60Hz+
This pump here
I am going to be pumping some water on dirt pads just enough to keep the dust down. I will have a 2,600 gallon water tank that I will use to water down pads from 100'x100' all the way up to 500'x500', and some stretches of roads.
The Tank on this page @ 2,635 gallons
I want an electric pump, and electric valves so I can control everything from in cab without having to get out and start a gas motor, etc.
Here is what I was GOING to do, but I'm not sure if it's the RIGHT thing to do.
I was going to hook up 10 Yellow Top Optima Batteris in Series (120V), to power the pump. Each Yellow Top has a RC of 155 minutes @ 20Amp/h drain.
I think this would work, but not sure. I have run into a mental road block, and would like some input from yall.
IF this setup works, my main question and concern is: How to charge these batteries? I would like to use a Solar panel/Maintainer charger for days the unit is not in use, but would also like to charge the batteries when I plug into the truck at the light connection.
I would assume that 10 Yellow tops would be more than overkill for this pump.
Judging by how much water I would be laying down, at full pump capacity, it looks like it would take atleast 20 minutes to lay down all my water.
Can somebody tell me if the battery/pump combo will work?
If I have enough capacity left over I would like to run a water cooler (Like a Porta-cool unit) for about 2 hours (max).
Something like these two,
Port-a-cool 16" 3-speed cooler
Port-a-cool 1/4 HP cooler
I can still be hooked up to my truck while running these units. I'm not sure if that would help enough or not.
Thanks guys! I really apprecaite it!
Merrick
This pump here
Merrick
