at cold start-ups (overnight temps in the 30's... i know that is summertime to some) i get this big plume of blue smoke with or without the heater plugged in during the night... . the Cummins manual suggests it is due to , among other things i have ruled out, the pump timing out of specs and/or the valves needing adjustment..... anyone have other suggestions i should consider on the smoke issue... . i will be adjusting the valves this weekend and will have to find an authorized Bosh dealer or good diesel shop to do the pump timing... . the local cummins dealer said they would not do it if the pump had never been off the engine... thanks
