Big Rain In L.a. Wet Inside Of Cab In 3500
2003 Front Driveshaft...
Replacement HEADLIGHTS 2008 DODGE RAM 2500
:confused: I think one of my clearance lights may be leaking due to the forward part of my overhead liner dripping water in my 2004 4500 cab. Does anyone know of a fix for this occurance?:eek:
There is a new style gasket... ... ... only available with the new style lights that was designed to fix that issue.
Bob
I had this problem with my 04. 5 and had the TSB done, no problems after that. And the 06 has not had this problem so it looks like they may have fixed it.
I installed the new type and they leaked so last spring I carefully applied silicon to all the mating surfaces and screw holes and still have a leak, what do you suggest?
Same problem here. Only saving grace I live in Cali where we get no rain
Look for a cracked lens, especially around the screws. I had hairline cracks in a couple on my 03 and ended up replacing them with a set of the upgraded lights.
