Well, I had a bad experience today. I was driving to an appointment and was running late. I didn't notice anything until I came out and noticed a huge puddle of transmission fluid around the front right corner of my truck. My first thought was that the transmission cooler sprang a leak. I popped the hood and discoverd that one of the cooling lines had come loose. There was transmission fluid everywhere. Luckly there was a friend there than ran me to the parts store to pick up so transmission fluid, a screwdriver and a funnel. 9 quarts of ATF later I got the transmission filled back up. On the trips to the store we saw that I had started leaking fluid at a stop light up the hill. Fortunately it was about 1000 yds down a hill and into the parking lot before I shut it down. I coasted the whole way which I would say is better than if I had been under power. What do you guys think? Did I do serious damage? I was thinking that I should drive it a couple hundred miles and then send off an oil sample.
Thanks for the input.
Dan
Dan
