Ozymandias
Seems Wyoming is a little windy....
Sure has me wondering about going through Wyoming with the 5th wheel. We have been there at Cheyenne traveling North and crossing over to South Dakota with no incidents.
Agreed, though when it gets really, really bad I have seen quite a few 5th wheels knocked over from it too. About plowed through the middle of one that laid over in the middle of an overpass when I was a crude oil hauler. Good thing the state trooper that just arrived at the off ramp right before that saw me coming, bailed out his cruiser and waved me off. You couldn't see the napping camper around the bend till it would have been way too late. But this was one of those few and far between weeks of nasty 75-80 mph+ gusting, 50 or so sustained. Big thing to keep in mind if you do have to deal with the wind is going slower will help you keep it under control. Better to get there a little late than not at all.That is the only place I've been where the wx radio channel gives current wind speeds on I80 and I25 from multiple locations. Towing a loaded 5th wheel usually isn't a problem, other than the increased fuel required. Empty travel trailers, otoh, sometimes get a little squirrelly.
I didn't like oil its different than gas. Oil is heavy so the compartments weren't as full so in a turn it had space to crawl up the sides and faster than you think your on the side, gas our compartments were pretty full with baffles so a full compartment didn't have much room to slosh around, Diesel being a little heavier than gas still was not as bad as oil
Ours were a little different this is an example I can't get the other truck and trailer to load but you get the idea View attachment 118050
Big, Tell Ozy what the little black circles are for on the front and rear cap of the trailer. I’ve seen them used before......
or are you talking about on the rear trailer bulkhead where they would bore holes in the tank with a Bronze drill bit to drain them incase of a rollover
