OK,,,, I think it finally time for me to do my turbo project... . I am planning to go to a smaller turbo housing... add an exhaust brake and add gages all at the same time... . Plus I have aproblem and need to ask a question... .
When I change my oil I routinely take the intake tube off of the compressor side of the turbo to access the oil filter... when it is off I usually check the bearings in the turbo... . lately I have foud a little bit of play in the radial direction, but no end play... should I assume that this bearing play is REALLY BAD and that I need to fix this soon?????? or is this normal???? In either case... does anyone no how easy this is to fix myself... . I used to be a pro-wrench... but my turbo and diesel repair skil sets are non existant. So I am learing.
