Hi guys-
Soon I'll be buying another set of tires, I strongly considered 19. 5's but just can't justify the expense for a vague 2-4x improvement in tire life + the cloudy issues of spinning the tire on the wheel, reduced wet weather performance etc.
I don't want to lift the truck because I have no need to go higher and like the existing suspension, tows well, would have to lift my fifth wheel jeep hauler etc. Yes I know the truck will be lifted a little if I increase tire Diameter)
does anyone make fender cutouts for the front? How about pushing the front axle forward an inch or so?
I'd really like to get something bigger than the 285/75's and life would be good if i could get away with a 36" tire (I have a good source of slightly used ones). The mods to the engine will easily handle the 10% gearing increase- I'm often looking for one more gear as it is.
what will fit as is? What do I need to do to run the 36's (Actually 37's which measure 36") I can live with rub on the control arms in a full lock turn. I don't wheel with the truck- my Jeep fills that need. Thanks for your input
