Transgo shift kit/TCS billet combo kit
Did the install yesterday; everything went relatively well except for the first hole I drilled for a firmer lockup was . 106 rather than . 083. It gives an option to drill 2 holes for an more firmer lock up but I went with 1 hole; just hoping the mistake of . 023 bigger doesnt make too much of a difference. The kit supplies some drill bits and not others; something didnt seem right after I drilled it so I pulled out my mic and... OOps!
I installed the front servo, accumulator, anchor and band strut; of course I wasnt about to drop the transmission to install the apply lever so I left it out, the original still looked great.
Of course, while I was in there, I adjusted the bands and now it is back together. I dont have enought ATF on hand to start it up and test it so i'll run to town this morning and pick some up. The biggest pain in my A** (besides the mess) was the park rod/sprag.
I did install a drain plug in the pan which should help me out when I drain it all again at the end of the month for anonther round of fresh fluid and filter at which point i'll seal it up with a new Mag-Hytec.
Saving up now for the new SC Govenor/solenoid conversion and Dtt Shift enhancer at which point my Trans should be good to go.
